Purple IPR render
I'm new to Octane and Houdini, so i'm probably doing something wrong but my IPR renders are purple, even though I applied a material to the mesh. Can someone take a look at my simple scene and let me know what i'm doing wrong. I'm running Houdini Indie 18.0.499 with Octane 2020.1.3.
- Attachments
- PurpleIPR.zip
- contains a screenshot and a .hiplc file in the zip
- (1.26 MiB) Downloaded 189 times
If you check the attributes, you will see that you have a prim attrib called shop_materialpath. Just delete it and you'll be good.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
Thank you galleon27 and juanjgon! I didn't even know how to delete a attribute and had to learn about attributes, so using the delete attribute node was the answer!
