Moving a light in the viewport disables its effect on object in the IPR. The light itself remains visible. Reloading the IPR shows a correct result.
Houdini 18.0.499
Octane 2020.0.1.3
GTX 1080Ti
Moving a light disables it in the IPR
C. RAM Capacity (i.e. 6 GB)
Sorry, but I can't reproduce this problem here. Do you have it with any scene?
I think that this problem had been reported some time ago, in an old Octane 2020.1 build. Can you please double check if you are working with Octane 2020.1.3.0 and if the plugin build that you are using is the right one for your Houdini version? You have this information in the plugin "About" window.
I double checked, versions seem to be in order. When I try to reproduce it, I only get that behaviour of the light not updating when the object is set to render as fur/curves.
