DOF specular noise
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
crackfox
i am having hard time with noise in the specular highlights amplified by the dof.
i tried cranking up the samples, which is a bummer because the whole scenes needs pretty low samplecount to look alright, but nothing helps.
hotpix removal cant reach it either but it helps a bit. adaptive sampling makes no difference apparently.
there are a quite a few older posts in different dcc subfori, but i just cant find any solution to fix this.
the size of sun or it intensity isnt excessive, the material is a plain metallic shader,
not sure if its an octane issue or a plugin one...
james_conkle
I've had this happen before and would love to hear an answer besides high sample rate. In the past I've just turned on adaptive sampling of course and used the de-noise feature but occasionally that'll leave artifacts on those spectacular highlights and animations.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
crackfox
thanks for reporting in james.
lets hope we get an official word for a fix.
cranking up samples is not really a viable solution at all.
the issue is becoming a bit of a showstoppper for me.
musab.almarri
Why not do dof in post ? , you can record scene depth pass instead
crackfox
doing it in post is really not an option except in very limited scenarios.
it introduces artefacts on the edges of objects for instance when the figure is standing against a background that is out of focus.
overlapping objects of any sort are a problem.
one could render out in separate planes (front, middle, back) and composite them, but that is not really a viable solution that.
ChrisHekman
crackfox wrote:doing it in post is really not an option except in very limited scenarios.
Could you show an example?
This is something that happens only with the unreal plugin? or does octane have issues with this in general?
crackfox
hi chris,
this last comment was referring to the advice to do the dof in post. in my experience it doesnt really work with overlapping values.
i just noticed that its sometimes hard to get rid of noise in very reflective (metal) dof areas when rendering with unreal...
this is more a general issue, i will get in touch with support when i stumble upon it again.
Return to “Unreal® Engine”
