Upgraded to 3x GPUs, now getting "CUDA error 2 on device 2"
lawrencepartington
I just bought an extra GPU. I now have a 2060, 2060S and 2070.
Clean and fresh install of *NVIDIA Graphics Driver 451.48* did not do anything.
When I render a different scene or when I deselect device 2 (which is the 3rd gpu, a 2060) I dont get this problem.
This scene is very complex as I have worked very long and hard on it, and it's overdue to get to the client hence the upgrade.
This is just upsetting because I just spilled out AU$1,100 on the non-subscription based version so I could use a 3rd GPU.
Thank you for reading, replying, anything! Appreciate it!!!!
The error log is as follows...
Started logging on 29.06.20 19:46:50
OctaneRender Enterprise 2020.1.3 (8010300)
CUDA error 2 on device 2: out of memory
-> failed to allocate device memory
OptiX error for device 2: [ERROR] "sbt->raygenRecord" is null
OptiX API error for device 2: Invalid value
device 2: RTX picking failed
device 2: path tracing kernel failed
whersmy
What Power supply are you running? Maybe it`s not enough for the extra WATT needed to run the third GPU? Do you see all the GPU`s with no errors/exclamation marks in Device Manager or MSI Afterburner?
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
lawrencepartington
whersmy wrote:What Power supply are you running? Maybe it`s not enough for the extra WATT needed to run the third GPU? Do you see all the GPU`s with no errors/exclamation marks in Device Manager or MSI Afterburner?
That's a good point, I currently have 1000W 80plus GOLD and I currently have a 1200W platinum coming in the mail
lawrencepartington
bepeg4d wrote:What is the exact model of your motherboard?
ciao Beppe
Currently have an X299 Aurous Master with an Intel Core i7 9800X 3.8GHz
for X99 or X299 motherboards and multi GPUs, please have at this solution here:
viewtopic.php?f=9&t=68650
ciao Beppe
