OctaneRender™ for Blender 2020.1.3 - 21.9 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgrade to Blender 2.83
  • Upgrade to Octane 2020.1.3
  • Support Universal Camera
    • Camera Data-Octane camera-Used as Universal Camera
  • Add "Adapt to Camera View Resolution" Mode
    • Camera Data-Octane camera-Adapt to Camera View Resolution
    • Basically, OctaneBlender will limit the rendered image inside the Camera boundaries even under preview mode(shown below)
  • Add "Octane Postfix Tag" in the "Output properties - Octane Output"
    • If given, this name will be concatenated to the file name as postfix(use $OCTANE_PASS$ to label to octane pass name)
    • Here is an example of how to use the Octane tags to customize the output name
  • Support on-fly material cast when importing Fbx/Obj
FIXES SINCE LAST RELEASE
  • Set the Camera Imager response to sRGB for the Perspective and to Linear/Off for the Camera by default
  • Checked file last modification timestamp when processing the image node. force to reload when the file is modified outside Octane
  • Fixed distorted in final rendering with Upsampling on(when resolution x is an odd number)
  • Fixed the Orbx Proxy render issue when the proxy including Placement nodes
  • Added warning for the object layer data in Orbx proxies - as the object layer data will not be available for the proxies with Placement or Group nodes
You can read about new features of OctaneRender™ 2020.1.3 here:
viewtopic.php?f=24&t=75172
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.9 (2.83)
Octane Server - Enterprise Edition - 21.9
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 21.9 (2.83) Linux
Octane Server - Enterprise Edition - 21.9 Linux
OSX
DOWNLOAD
Blender Octane Edition - 21.9 (2.83) OSX
Octane Server - Enterprise Edition - 21.9 OSX
