OC 2020.1 How to engage NVLink memory pooling?
Moderator: BK
Jazbee
I have 2x RTX 2080ti connected via NVLink, but Octane doesn't seem to use the second GPU's memory. I set the "Peers" in device preferences but it doesn't seem to change anything.
I know Octane is NOT supposed to show a larger memory pool in the System panel. Instead, once the main GPU's memory limit in exceeded it should overflow into secondary GPU's memory. Thing is, once the single GPU memory limit is exceeded, Octane starts using Out-of-Core memory instead of VRAM on the second GPU, as it would without NVLink. I'm using 451.48 Nvidia drivers and 2020.1.0.55 version of Octane.
Am I missing something?
2x RTX 2080ti, AMD Ryzen Threadripper 1920X, 128GB RAM, Win10 Pro 64, Dual Monitor Setup
I suggest asking OTOY this question, as it is not specific to the plugin.
janmorek
Hi Jazbee,
Did you find the solution ?
Return to “DAZ Studio”
