hi,
i am trying to export a depth pass.
i activated it in the target settings and enabled the pass under export settings.
the samples get all computed but the frames do not progress or save out .
capturing video simply keeps on running in the lower right corner and the export hangs on frame 0.
rendering passes hangs sequence export
Moderator: ChrisHekman
- ChrisHekman
I just tested this with both the z-depth renderpass and the z-depth info-kernel and it works here. Could you elaborate about your process. Are there steps you can give me to reproduce this issue?
