OctaneRender™ 2020.1.3 [superseded by 2020.1.4]
mojave
Dear all,
We are happy to share a new release of Octane.
Octane 2020.1.3 is our latest maintenance update and the version currently recommended for production use.
Make sure to use a NVIDIA Studio driver with version at least 435.80 for Windows or 435.12 for Linux to enable support for RTX hardware acceleration. There are no OSX drivers that currently support RTX.
OctaneRender 2020.1.4 has superseded this build.
Should you find any issues with this release please report using this thread so we can make sure we provide you with the best feedback.
Changes since OctaneRender 2020.1.2:
Bugfixes:
  • Fixed regression causing VDB files of version 224 to not to load.
  • Fixed issue causing the searchbox to be canceled when clicking on the scroll bar.
  • Fixed mix material not rendering the auto-bumped normal when multi-layer material was used in one of the material slots.
  • Fixed issue causing the light pass to not to capture direct light if the cast shadows option was disabled.
Other changes:
  • Allow OSL texture and projection shaders to have multiple outputs from which Octane will use the first one.
  • Allow OSL shaders to have float output which will produce a greyscale color.
Currently under investigation:
  • Some users have reported issues with old CPUs due to AVX instructions, this affects standalone, slave and plugin builds (will be fixed in 2020.1.4).
  • Some scene updates on instances which use texture displacement make them to temporarily disappear (will be fixed in 2020.1.4).
  • CUDA error in some scenarios when using NVlink due to mismatching barriers.
Downloads
Downloads for Enterprise subscription users:
OctaneRender Enterprise 2020.1.3 Standalone for Windows (installer)
OctaneRender Enterprise 2020.1.3 Standalone for Windows (ZIP archive)
OctaneRender Enterprise 2020.1.3 Standalone for Linux
OctaneRender Enterprise 2020.1.3 Standalone for OSX
OctaneRender Enterprise 2020.1.3 Render Node for Windows (installer)
OctaneRender Enterprise 2020.1.3 Render Node for Windows (ZIP archive)
OctaneRender Enterprise 2020.1.3 Render Node for Linux
OctaneRender Enterprise 2020.1.3 Render Node for MacOS
Downloads for Studio subscription users:
OctaneRender Studio 2020.1.3 Standalone for Windows (installer)
OctaneRender Studio 2020.1.3 Standalone for Windows (ZIP archive)
OctaneRender Studio 2020.1.3 Standalone for Linux
OctaneRender Studio 2020.1.3 Standalone for OSX
Happy rendering
Your OTOY NZ team
frankmci
It's great to see multiple node outputs starting to become a reality. Also, the "Currently under investigation" section is a very good idea, and would be good to keep updating that section between releases. It would provide a universal first place to check when experiencing problems, and could save both users and developers a lot of time, both troubleshooting, and fielding questions.
Thanks for the update!
Kalua
Thanks, team!
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
Lewis
Guys, please can you ADD "Perspective Correction" option to Universal Camera? That is missing currently so it's not useful for Arch-Viz stuff :(. Regular ThinLens camera has it and works perfect but new UC is missing it :(.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
james_conkle
Thanks! This has been super stable which is very exciting :D
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
Kalua
Lewis wrote:Guys, please can you ADD "Perspective Correction" option to Universal Camera? That is missing currently so it's not useful for Arch-Viz stuff :(. Regular ThinLens camera has it and works perfect but new UC is missing it :(.
It was corrected at this built. We now have lens shift for universal camera as well. You can get perspective correction with this.
Lewis
Nope that i snot same, Thin Lens camera also has lens shift, that's nothing new and not same feature.
Look at this screen-grab,
Problem with Universal Camera and "Keep Upright" option is that it ignores Y(Bank) rotations of camera (in my case it's 17 degrees) so OpenGL and render do not match.
Lewis
Skype - lewis3d
ICQ - 7128177
Kalua
Yes it works:
You should use lens shift values - and you will get the very same result. No need to set "keep upright", you only need to set camera rotation straight and play with lens shift values.
Lewis
Kalua wrote: Yes it works:
Well that's the point i don't want camera straight, if id' want always 90 degree angles i'd not even need perspective correction :).
My point is that Thin Lens camera has same lens correction settings as universal camera so that is nothing new but UC has no perspective correction button/feature and i can't match it to my openGL in that case so it's pretty much useless for aiming camera if is not same as in OGL so it's omission and they Souths add it to Universal Camera also (they obviously have code for it since it's present on ThinLens camera already).
Not sure why are you arguing it? What is the problem if it has same options/features as ThinLens camera already has ?
Would that feature bother your workflow or what? You'd still be able to use lens correction and straight camera angles (which i do not want to do as i explained it's not matching my openGL)
I see it as win-win, no downside of including that feature - right ?
cheers
Lewis
Skype - lewis3d
ICQ - 7128177
Kalua
cheers
It doesn't bother me at all to have a "perspective correction¨check box... I just said you can achieve the very same effect with "lens shift". "Perspective correction" checkbox is a handy tool wich actually is a shift control lens.
While is not as handy as you like, you may use it as a workaround while Otoy implements a "perspective control" checkbox in Universal.
