How to add snow to geometry with MixTexture & FallOffmap ?
omegear
So I'm trying to figure out a way to add snow or sand with mixtexture and a fall off map.
It seems to work on a perfectly symetric object, such as a sphere but when I use another geometry (made in 3Dcoat) it doesn't seems to work quite well.
Any suggestions regarding this ?
try to use an Octane Gradient node in between the falloff map and the amount, to fine tune the starting point, and the transitition.
ciao Beppe
frankmci
What do you mean by, "doesn't seems to work quite well"? What is the difference between your expectation and the actual behavior?
