Octane 2020.1 For Unreal Engine - v0.36: Fixes + UE4.23
Moderator: ChrisHekman
ChrisHekman
Octane for Unreal Engine 0.36
Changes:
  • Temporarily added Unreal 4.23 support back in.
    The sith rule of two will still apply in the future, which means I will aim to keep the last two versions of unreal supported
Fixes:
  • RenderTargetActors now behave correctly when going in and out PIE
  • Fixed issue where rendertarget camera could not be changed during PIE mode
  • Octane scenetime is now correct when sequencer orbx export has a custom (non-zero) start frame.
  • OctaneRenderTargetActor settings are now correctly reset when exiting PIE
  • OctaneRenderTargetActor settings are now correctly reset when sequencer finishes
  • Rendertarget changes now dirty the scene (this will trigger a save request from unreal when exiting or closing a level)
  • Focal length is now greyed out when set by the camera or viewport
  • Hide actor in game now works correctly
  • Fixed alpha texture bug
  • Fixed alpha textures not working after exporting to orbx
  • Reduced alpha textures memory footprint significantly
  • Fixed empty transform UV pin bug for converted materials from orbx files
  • Octane Alpha Nodes now correctly use the alpha channel of the connected unreal texture
UE 4.25
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_25.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_25.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_25.exe
UE 4.24
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_24.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_24.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_24.exe
UE 4.23
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_23.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_23.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_23.exe
EvolverInteractive
Thanks so much, you saved me soo much time on the alpha fixing.
adamnerva
Thanks for the fixes, Chris!
