Hi
I have Lightwave 2020 running octane enterprise, if I render the scene in LW 2019 its fine if I try it in LW 2020 I get a Render Failure message, I'm using Octane_2020.1.0.6_LightWave_2020.0. Anyone else getting issues ?
The Log message
[profile] Function "GetPreviewImage" over "" execution time: 0.002 seconds
00:00:06 (0006.92) | IPR: close the IPR preview window
00:00:06 (0006.92) | IPR: finish render thread command
00:00:06 (0006.92) | IPR: abort render thread command
00:00:06 (0006.92) | IPR: reset image callback
00:00:06 (0006.92) | IPR: wait for the getPreviewImage function
00:00:07 (0007.02) | IPR: free the OpenGL buffers
00:00:07 (0007.02) | IPR: rendering done
00:00:07 (0007.02) | Stop rendering scene ...
00:00:07 (0007.30) | ... Rendering stopped
00:00:07 (0007.30) | IPR: abort render thread command finished
00:00:07 (0007.30) | Close and free scene, free buffer: 0, reset scene: 1
00:00:07 (0007.30) | ... setRenderTargetNode(NULL)
00:00:07 (0007.30) | ... update()
00:00:07 (0007.30) | ... getRootNodeGraph()->clear()
00:00:07 (0007.30) | Scene closed
00:00:07 (0007.30) | IPR: free the snapshots system
00:00:07 (0007.30) | IPR: IPR preview window closed
00:00:07 (0007.30) | Octane Render for Lightwave, end of log system
LW 2020 error
Are you sure that you have the right plugin for LW2020? You can check that in the plugin "About" window. Also, you should check that you don't have two (or more) mixed plugin builds installed at the same time in the Layout.
