[OCTANE CRASH] Logs inside
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
stefanmathez
A. Operating System, including version: Win10
B. Graphics Card(s) model 2x1080-ti + 1x2080-ti (CRASHES STARTED AFTER SWAPPING CARD WITH RTX ON)
C. RAM Capacity 64GB
E. OctaneRender Standalone version, if installed: 2020.1
F. OctaneRender plugin version: 2020.1-R7
G. Host application version, including build number if available: Cinema 4D R21.115(RC)
H. A detailed description of the issue and steps to reproduce it (Include Screenshots or video capture), as well as an example scene if applicable: C4D crashes when working with live viewer with RTX ON. Nothing crashed before swapping one 1080-ti for the 2080-ti. While rendering animations the crash reboots the entire system.
I. Copies of the Octane Log window and Console window outputs: Logs Attached
Thank you for your assistance as I'm running against a deadline.
octanelog_report.zip
log from scene
(4.01 MiB) Downloaded 239 times
bugreport_20200609_034949.zip
bugreport
(2.4 KiB) Downloaded 232 times
stefanmathez
D. Nvidia driver version (i.e. 7.50, 7.5.22): 446.14
I'm going to try to look at TdrDelay and reinstall all drivers, but any hep will be hugely appreciated.
Some Win 10 users have set the TdrDelay at 60, to solve their stability issues with CUDA.
I am testing this solution right now, will provide feedback.
Stefan
stefanmathez
stefanmathez wrote:D. Nvidia driver version (i.e. 7.50, 7.5.22): 446.14
Stefan
TdrDelay at 60 changed this and it didn't do anything. Computer still shuts down mid render.
It's a hardware level issue if your comp shut downs. Also RTX mode is not much stable as without it.
What would be great that if you can define which or what triggered or started doing this. And please send a sample scene that causes problems.
stefanmathez
aoktar wrote:It's a hardware level issue if your comp shut downs. Also RTX mode is not much stable as without it.
Thanks Aoktar, I've sent you a PM.
stefanmathez
I've added further info in the PM and another Log for you. Thanks for your hard work Aoktar.
stefanmathez
I am testing with 2 GPU instead of 3, to see if the crashes are related to PSU.
I might be right on the end of the PSU capacity and that might be causing the issues. :cry:
stefanmathez
stefanmathez wrote:I am testing with 2 GPU instead of 3, to see if the crashes are related to PSU.
Run test all evening. 2 GPUs, same CUDA error 700 on multiple different scenes.
It's not the PSU :|
CUDA error 700 is always Nvidia driver related.
Please use DDU to remove all the installed Nvidia drivers, then perform a clean installation of the latest Studio driver 442.92.
ciao Beppe
stefanmathez
bepeg4d wrote:Hi,
ciao Beppe
Ciao Beppe,
Unfortunately not. I have done so, I have also created a fresh rig with a new motherboard and CPU and only one 2080ti and with RTX on, the Octane RTX Benchmark crashed :geek: :lol:
Tom Glimps
badge icon
Thanks for reporting. In some cases DDU and clean driver installation helps.
RTX stability is improved, but still needs some work, so it makes sense RTX off does help.
I suppose we have to wait for more stability for now.
Return to “Bug Reports”
