starting frame and camera
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
crackfox
hi chris,
when exporting the sequence with a custom starting frame, it seems that the camera is disregarded and i see something completely else.
not sure its an arbitrary viewport but in any case i cant seem to continue a sequence if a pause the render because of this.
crackfox
so the workaround would be to limit the range in the sequencer if i ever want to continue rendering from a specific frame.
custom starting frame in the rendering settings is acting very strange but atleas i can render now in stages.
EvolverInteractive
Or at the bottom render sequence menu: just start on the frame you want, it's already built into Unreal. No need for a workaround
ChrisHekman
I tried this in the upcomming build, and the camera works correctly when starting from custom start frames.
I did make some changing in how rendertargets work in play mode and the sequencer, so maybe its fixed now.
crackfox
good to know chris thanks.
evolver, thanks for the tip, but i am having camera issues with that setting.
setting the boundaries withing the sequencer is not a pain actually, so no biggie.
Return to “Unreal® Engine”
