C4D Noise Looping
FiveD
Hello - please can you confirm if native C4D noise looping is supported?
Please see attached scene file for example, simple scene - 100 frames, 25f/sec, C4D noise mapped to diffuse node.
Setting the noise "Loop Period" to 4 seconds but does not loop. If I create a Standard C4D material, noise looping works as expected.
Any ideas?
noise-test.zip
(79.21 KiB) Downloaded 247 times
FiveD
Can anyone validate if my issue is expected or they can reproduce?
If not, I'm happy to learn if I've made a mistake in the attached scene file.
frankmci
From what I can see, the lack of looping is related to the "Use OSL for C4D noise/gradient (Experimental)" option in Octane Settings/Settings/C4D Shaders. If you turn that off, it loops as expected.
Note that we don't claim our implementation pretty perfect to match the c4d noises. Seems like there's a missing brick. But we cannot fix it without break backward compatibility
FiveD
frankmci wrote:From what I can see, the lack of looping is related to the "Use OSL for C4D noise/gradient (Experimental)" option in Octane Settings/Settings/C4D Shaders. If you turn that off, it loops as expected.
That was it! Thanks Frank.
FiveD
aoktar wrote:Note that we don't claim our implementation pretty perfect to match the c4d noises. Seems like there's a missing brick. But we cannot fix it without break backward compatibility
Not a problem, I wanted to know if it was "end user error" or a "missing brick". Thanks for your time and love your work!
timtadder
I am having the same problem and when I turn off "use osl for C4d noise gradient" my noise no longer works (of course) so is using a c4d noise through a bake texture no longer support looping? I am attaching the file, with the texture with the noise. Any one have a solve for this?
timtadder wrote:I am having the same problem and when I turn off "use osl for C4d noise gradient" my noise no longer works (of course) so is using a c4d noise through a bake texture no longer support looping? I am attaching the file, with the texture with the noise. Any one have a solve for this?
Why do you choose it? Best is to don't do that
timtadder
I'd like to be able to use procedural noise to create a loop using the material, the way the material mixes on the geometry. The only way I can do that with the octane noise is to use the transform to control the animation which looks non organic and defeats the purpose of the noise? Is this impossible to do with octane? Easy to do with other render engines but I like Octane.
AWOLism
I'd just like to add that personally I would sacrifice backward compatibility to be able to perfectly loop the C4D noises without baking.
C4D R2026 + Octane 2026.1 | Windows 11 Pro | 128 gb ram | 1 x RTX5090
