OctaneRender™ for Blender 2020.1 - 21.8 Final Release [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Enhanced the Motion Blur System
    • Supported MantaFlow motion blur
    • Supported deforming object motion blur
    • Supported hair motion blur
  • Enhanced the Octane Sphere Primitive system
    • Supported to use sphere primitive for meshes and imported point clouds ( "Properties-Octane Properties-Sphere Attributes")
    • Supported to use sphere primitive for the Particles and MantaFlow ( "Particle Property-Octane Sphere Primitive Settings")
    • Spheres primitives are way faster to render since there's no geometry present in the scene
    • OctaneBlender will use sphere primitive as particle element when the "Render As" is "Halo" and "Use as Octane Sphere Primitive" is enabled
  • Supported Multiple view layer with the render pass system
  • Enhanced preview cache resource system
FIXES SINCE LAST RELEASE
  • Fixed the brighter background issue under IPR when both "Keep Environment" and "Alpha Channel" are on
  • Supported OctaneDB for Volumes
  • Moved GI Mode checkbox just under Kernel Type
  • Fixed camera motion blur bug
  • Fixed image format updating issue
  • Fixed the "Save to OctaneDB feature" feature
  • Fixed the OSL update issue
  • Fixed the update issue for the image node with movie sequence
  • Fixed the AO texture issue
KNOWN ISSUES
  • There is a crash issue when modifying primitives under the experimental RTX acceleration with the latest drivers. As workarounds, please stick to older versions as long as RTX is supported. Besides, A fix for it is coming soon.
You can read about new features of OctaneRender™ 2020.1 here:
viewtopic.php?f=24&t=74586
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.8(2.82a)
Octane Server - Enterprise Edition - 21.8
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 21.8 (2.82a) Linux
Octane Server - Enterprise Edition - 21.8 Linux
OSX
DOWNLOAD
Blender Octane Edition - 21.8 (2.82a) OSX
Octane Server - Enterprise Edition - 21.8 OSX
