Enable Deformation MB
Houdini Integrated Plugin
Ebo
Hi, I have rendered my scene with Deformation MB last night but today I come to my PC and want to check and adjust the motion blur and my scene keep crashing even after restarting my PC. Really annoying problem and the scene is too big to send it to you sorry.
Ebo
It basically looks like I can't render the motion blur in IPR as render to disk works well. Hope that may help.
juanjgon
It is hard to know what could be the problem without the scene to reproduce this problem here, but can you please at least enable the Octane log file in the plugin options panel and send me the log that you get after the crash?
Ebo
Hi, I saved the log file. Also, it does not crash when I want to render deformation and fur MB in IPR it just stops reacting and get's to a non-responding situation.
octane.log
(62.88 KiB) Downloaded 148 times
juanjgon
Hmm, and do you say that this problem only happens in the IPR? It is really weird. Can you please disable the multi-thread scene extraction option in the Octane ROP node to check if it helps? If the problem is still there with the multi-thread option disabled, can you please send me the log file that you get with this option disabled?
I'm trying to figure out what is the object that could be related to this issue because without the scene it is going to be really hard to know what could be the problem.
Ebo
it works well with multi-thread option disabled. Thank you
Return to “Houdini”
