octane v4 network performance
athosrojas
I had been using version 4.02.1 of the octane render max plug in, and had been having lag problems in the interface and when using the editor material together with the octane viewport. crashing 3dmax. I saw that doing the update to 4.05.6.30 the problem with material editor was solved, but now I have another problem, network render. when I use the slave it makes the render 2x times more slow. as if the master was waiting for the slave. in the old version I had a speed boost of 30% using network render. now i get to render 2x times as slow. any tips?
( i using gigalan network and both machines are same config , same cpu same memory , same video board Rtx2060super)
paride4331
Hi athosrojas,
I think your issue doesn't depends on the v4.05 update.
set max tile to 8; you can also encrease Paralles sample.
Regards
Paride
athosrojas
your solution dont works, this is drive me crazy. today i reset my router think can help, what i dont undestand its was working before ,now stop works.
paride4331
athosrojas wrote:I had been using version 4.02.1 of the octane render max plug in, and had been having lag problems in the interface and when using the editor material together with the octane viewport. crashing 3dmax. I saw that doing the update to 4.05.6.30 the problem with material editor was solved, but now I have another problem, network render. when I use the slave it makes the render 2x times more slow. as if the master was waiting for the slave. in the old version I had a speed boost of 30% using network render. now i get to render 2x times as slow. any tips?
Hi athosrojas,
using 2x RTX2060super you should run 2x compared to 1x RTX2060super
Regards
Paride
athosrojas
thx for you reply man. i just dont know whats happen. i made update for my other 3dmax licence so i can put my 2 machines to render diferent shots. but i preffer network render. btw if someone show me a way to solve that i will be very gratefull
Return to “Autodesk 3Ds Max”
