Vertex displacement issue
C. RAM Capacity (i.e. 6 GB)
When using procedural textures (noise, turbuilence etc) with vertex displacement a UWV projection node has to be added to make it work properly (object has UV map). With bitmap textures it is not needed.
System – Windows 11
System – Windows 11
- linograndiotoy
You should always use a Projection node when using procedurals.
By default procedurals area applied using the XYZ Projection in World mode. That's always true for any input, not only for Vertex Displacement.
Moreover, to have AutoBump work correctly, you need to also use Local Mode if XYZ Projection is used.
Where is this mode located? I can see only Vector space with Object and tangent modeslinograndiotoy wrote:...
System – Windows 11
System – Windows 11
- linograndiotoy
XYZ Projection is one of Octane's available projections, not a Displacement option.J.C wrote:Where is this mode located? I can see only Vector space with Object and tangent modeslinograndiotoy wrote:...
Ok, I've found this.linograndiotoy wrote:XYZ Projection is one of Octane's available projections, not a Displacement option.J.C wrote:Where is this mode located? I can see only Vector space with Object and tangent modeslinograndiotoy wrote:...
System – Windows 11
System – Windows 11
