Hello Everbody!
I plugged an animated saw wave texture in the emission slot of my diffuse material and when i hit render the offset parameter of my saw wave textures dont work.
But when i start interactive Render and move the timline it works.
How can i fix this?
Greetz
Animated saw wave texture in emisson slot wont render
- paride4331
- argus_medya
The mesh is proxy already. This time i selected all meshes and turned into movable proxy but nothings changed. I even restarted the scene but
If i plug the the saw map into the diffuse slot it works.
- paride4331
Hi argus_medya,
could you share your issued scene please?
Regards
Paride
Regards
Paride
- argus_medya
Hi ,here is the scene. I created a new scene but still dont work.
Thank you
Thank you
- Attachments
- CABLE_TEST.zip
- MAX 2019 - Octane 4 6.30
- (57.53 KiB) Downloaded 174 times
- argus_medya
Has somebody any solution for it? now i use an animated uv gizmo to drive the lightflow but in some areas weird things happen.
- paride4331
Hi argus_medya,
I sent your issue to developers.
Regards
Paride
Regards
Paride
