As I was rendering away, I noticed my FPS started to drop. My test scene was at first runing at 5.05FPS but dropped to 3.83FPS after about 10 minutes of rendering a heavy scene. That's a big drop! I found out it was the temp on the card that was too high. I guess the GTX580 has a fail safe or the card just can't handle high temps. When it reached 97 degrees, the FPS started to drop and the temp wouldn't go higher than 98 degrees. The GTX580 was actually performing slower than my GTX470 at one point!
My PC tower has the sides off to get more air in, but in this case it was just not enough. I had to place a 120mm fan just outside the tower to blow air on the card. This fixed the problem and the temp lowered to 89 degrees at full load and I had stable FPS.
The temp on the Gainward Phantom should be 5-6 degrees lower than the reference cards, so I would guess some people in here would get the same problem I ran into. The only problem is that they would not noticed this, if they are using the 2.48+ versions, as you can't check the realtime speed since the FPS is gone in those versions. That's why I'm posting this.
The threshold seems to be around 97 degress where the performens will start to drop. So this is just a notice to GTX580 owners to check their temp now and then, as it would suck if the performens will drop and you don't know about it
