image refresh not working in shader editor
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
protovu
Hello,
Currently in Blender_Octane_Edition_2020.1_21.7_stable, for Win10.
Image files are not reloading upon clicking the reload button.
Thank you
amd 3090
2 rtx 2080s
64 r
pegot
Not sure if this is the same issue but I started having lots of crazy refresh issues with 21.7. Materials are often not updating unless I plug/unplug them or hide and then show some geometry. Materials downloaded from the Live DB seem to be the most problematic. Very difficult to work interactively. Even if I completely unplug a material from its output node, the change is not reflected in view port and still shows the rendered shader.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
protovu
Perhaps a different issue. I only guess this because I use another Octane plugin for a different software, Carrara.
It also has this reload texture issue. In the case of Carrara, reloading the scene updates the texture, and the reload button does nothing, like now with Blender.
But that said, the Carrara plugin displays none of the issues you describe.
One annoying workaround for Blender reload: insert the wrong texture - one you don't want, and then insert the correct texture. This updates the render preview.
protovu
Anything happening with this?
Image refresh does not work in shader editor.
If helpful: The refresh button of the shader editor does refresh the image within the UV editor, but not within the shader editor, nor with the rendered image.
Return to “Bug Reports”
