hide hdri
kittysoman2013
Hi all, a beginner question.
Im using an hdri sky for my exterior environment, I don't want to see the image itself but only the original octane sky.
is it possible?
thanks
yes, you can use the Visible Environment node with the Octane daylight node in it, and enable the Backplate, Reflection, and/or Refraction.
In this way, the Environment node with HDRI will be used for lighting the scene, while the DAylight will be used as background.
https://docs.otoy.com/StandaloneH_STA/S ... ht=visible
ciao Beppe
