Zdepth
HHbomb
I use 2020.1 - 10.11 and I wonder if Zdepth is working...
To test I use :
a = renderers.current
a.kernel_zDepthMax = 1
and change a.kernel_zDepthMax value.
But Nothing happen in viewport "Z-depth", all geometry is full white.
Any clue ??
samsue
Hey,
You have set up on "Info Passes Setup / z-depht max." and the Z-Depht Render Element value to the same value?
HHbomb
Yes, but I'm stupid....
I use mainly render viewport to render my images... so this setting don't do anything... I must switch to info channel kernel mode to use a.kernel_zDepthMax... or render image with "render".
Thanks for help.
EDIT : in fact, I can change value of zdepth in render element with :
a.infopasses_zDepthMax = value
Return to “Autodesk 3Ds Max”
