Node Selector Node Input number
- blobbybarack
- Contact:
Can we set more than 8 pins with the selector node ?
- bassruettler
If you want to switch textures/colors, then you could write an osl texture like this:blobbybarack wrote:Can we set more than 8 pins with the selector node ?
shader Texture(
color in0 = 0,
color in1 = 0,
color in2 = 0,
color in3 = 0,
color in4 = 0,
color in5 = 0,
color in6 = 0,
color in7 = 0,
color in8 = 0,
color in9 = 0,
output color c = 0)
int i = 0;
if (i == 0) { c = in0; }
if (i == 1) { c = in1; }
if (i == 2) { c = in2; }
if (i == 3) { c = in3; }
if (i == 4) { c = in4; }
if (i == 5) { c = in5; }
if (i == 6) { c = in6; }
if (i == 7) { c = in7; }
if (i == 8) { c = in8; }
if (i == 9) { c = in9; }
Be aware that the node selector is not a standard Octane shading node. It is a tool created on the plugin side to physically rewire the shader node tree while building complex HDAs, like the render target.
In a shading workflow, probably the material mixer node, or an OSL solution like the one posted above could be better.
- blobbybarack
- Contact:
Thank you juanjgon.
I still don't have the Osl reflex for now.
This is a very elegant way to takle this problem.
