[21.7] Adding color OSL input pin doesn't show color picker
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
grimm
If you add a color pin to a OSL script it doesn't show it as a color swatch, which you can click on and open a color picker like it does in the Cycles' OSL node.
color Background = color(0,0,0),
Jason
linograndiotoy
grimm wrote:If you add a color pin to a OSL script it doesn't show it as a color swatch, which you can click on and open a color picker like it does in the Cycles' OSL node.
Jason
That's a limit with all plugins right now.
You'll need to connect an RGB Color node to edit the value.
grimm
Thanks Lino. :)
Jason
linograndiotoy
You're welcome!
Return to “Bug Reports”
