2020.1 / 21.7 - Materials not showing
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
ChrisH
I'm having some troubles with the materials in the viewport. This has happened in two different files (and for different materials & objects in the same file).
Materials "disappear" from some objects (but not others). The materials come back if I toggle Edit mode (but not if I toggle rendered view on and off).
Please note that these are not materials or objects that I have worked on this session (the materials were assigned to the objects when I opened the .blend)
(I've also have issued with the viewport not updating when doing changes to the material [Material caching disabled]).
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
linograndiotoy
Would it be possible for you to share the scene showing the issue with precise steps to reproduce it?
Thanks!
Return to “Bug Reports”
