OctaneRender for Maya 4.05-13.49 [STABLE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 4
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 4.05
Please read the new features implemented from Octane Standalone 4 version our blog post.
Changes since version 13.48:
  • Fixed the settings' issue: the out-of-core size input fields were treated as bytes instead of megabytes.
Windows DOWNLOAD
OctaneRender for Maya 4.05-13.49 Demo
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 4.05-13.49 [Windows]
OctaneRender for Maya Studio 4.05-13.49 [Linux]
OctaneRender for Maya Studio 4.05-13.49 [MacOS]
churumbela
Is it correct to asume that this plug-in doesn't have working Scattering nor Absorption mediums?
churumbela
I've done some more testing. It seems that connecting Mediums to Diffuse shaders is broken... altering values on the Medium node doesn't even restart IPR.
However, using Mediums with a Glossy material (as shown in the youtube Octane for Maya videos) does work.
blackshore
I understand that this is a older version but still supported?
Do anyone know how to get this OSL texture working with Octane:
https://github.com/cuckon/scratched/blo ... cratch.osl
I'm currently getting following error in maya+octane:
// Error: Octane: Failed to compile OSL texture node:
error: No shader function defined
System: win7 64bit
Maya: 2018
Octane:4.05
Maya plugin: 13.49
OSL shader:
// Micro Scratched Texture
// Author: John Su <[email protected]>
// An OSL shader that generates texture to make swirly micro scratch look by
// controlling the anistropy and roughness.
// The original idea is from Hang Li(悬挂鲤) and Ben Paschke. Here I implemented
// it using OSL and exposured some arts friendly parameters.
#define DIVISION 40
#define DEBUG(_) Cf=_; return;
float line(point p, float direction, float width){
    float theta = direction * M_PI;
    float k = tan(theta);
    float distance = abs(k * p[0] - p[1])/sqrt(k * k + 1);
    return 1 - step(width*0.5, distance);
shader scratch(
	float density=0.1,
	float roughness_min=0.0,
	float roughness_max=0.01,
	float roughness_default = 0.1,
	float anisotropic_min = 0.1,
	float anisotropic_max = 0.2,
	float anisotropic_default = 0,
    float width=0.001,
    float offset=0.0,
    output color Cf = 0
    float delta = 1.0/(DIVISION - 1);
    float max_radius = sqrt(density);
    int max_search_cell = (int)ceil(max_radius/delta);
    point index = point(round(u/delta), round(v/delta), 0.0);
    point shading_p = point(u, v , 0.0);
    point current_index;
    point current_origin_p;
    float scratch = 0, direction=0;
    float roughness = roughness_default, anisotropic = anisotropic_default;
    for (int x = -max_search_cell; x <= max_search_cell; ++x){
        for (int y = -max_search_cell; y <= max_search_cell; ++y){
            current_index = index + point(x, y, 0);
            current_origin_p = (current_index + (hashnoise(current_index) - 0.5)) * delta;
            direction = hashnoise(current_index + vector(123, 456, 0));
            scratch = line(
            	current_origin_p - shading_p,
            	direction,
            	width * hashnoise(current_index)
            if (scratch)
            	roughness = roughness_default + mix(
            		roughness_min,
            		roughness_max,
            		hashnoise(current_index + vector(123, 456, 1))
                anisotropic = anisotropic_default + mix(
                	anisotropic_min,
                	anisotropic_max,
                	hashnoise(current_index + vector(123, 456, 2))
                break;
        if (scratch)
            break;
    Cf = color(
    	roughness,
    	(direction * 0.5 + offset) * (scratch > 1e-4),
    	anisotropic
The osl texture works fine in standalone. It just causes issues in maya for some reason.
BK
blackshore wrote:I understand that this is a older version but still supported?
System: win7 64bit
Maya: 2018
Octane:4.05
Maya plugin: 13.49
OSL shader:
#define DIVISION 40
shader scratch(
	float density=0.1,
    float width=0.001,
    float offset=0.0,
    output color Cf = 0
            scratch = line(
            	direction,
            if (scratch)
            		roughness_min,
            		roughness_max,
                	anisotropic_min,
                	anisotropic_max,
                break;
        if (scratch)
            break;
    Cf = color(
    	roughness,
    	anisotropic
hi Blackshore,
Thanks for the post.
We are unable to reproduce this error.
Please find the file attached using the same OSL compiled using texture node.
ForBlackshore.zip
(9.66 KiB) Downloaded 192 times
cheers
Kind Regards
bk3d
blackshore
Your shader works. Not sure on what you did.
I have added the OSL here if there is more wish to download it.
Thanks btw!
scratch.osl
Scratch OSL - Working
(2.78 KiB) Downloaded 172 times
BK
blackshore wrote:Your shader works. Not sure on what you did.
Thanks btw!
Hi Blackshore,
Thanks for letting us know it worked.
We copied the code and then compiled it.
cheers
Kind Regards
bk3d
Locked
