How to export only render passes whit no beauty calculation
Sub forum for help and tutorials.
growingdot
Hi there,
Is there any way to export only render passes, for example render layer mask, with no beauty calculation ?
I don't know how to do it, so generally i use the composite tag of c4d, and rener with c4d standard, but in this case i have Octane displacement in my scene and so the c4d masks do not match correctly ...
Thank you for your attention :)
You can't avoid because at least one sample should be calculated. But you can set maxsamples=1 for quick results.
Return to “Help / Tutorials”
