OctaneRender™ for Blender 2020.1 - 21.7 [OBSOLETE]
azen
OctaneRender™ for Blender plugin for Windows, Linux and OSX. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to 2020.1
  • Add two strategies as rapid screening methods to detect whether a mesh is changed(dirty)
    • Edit Mode (Default) (A mesh will be marked as dirty and reloaded once the edit mode is on)
    • Select (A mesh will be marked as dirty and reloaded once it is selected)
FIXES SINCE LAST RELEASE
  • Fixed the VDB imported scale update issue
  • Fixed distorted region render issue
  • Set auto smooth as True by default
  • Fixed the render update failure when renaming materials
  • Fixed the OSL shader reset issue
  • Fixed crash when starting render without server
  • Fixed slow camera navigation issue
KNOWN ISSUES
  • There is a crash issue when modifying primitives under the experimental RTX acceleration with the latest drivers. As workarounds, please stick to older versions as long as RTX is supported. Besides, A fix for it is coming soon.
You can read about new features of OctaneRender™ 2020.1 here:
viewtopic.php?f=24&t=74586
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.7(2.82a)
Octane Server - Enterprise Edition - 21.7
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 21.7 (2.82a) Linux
Octane Server - Enterprise Edition - 21.7 Linux
OSX
DOWNLOAD
Blender Octane Edition - 21.7 (2.82a) OSX
Octane Server - Enterprise Edition - 21.7 OSX
