OctaneRender™ for Blender 2020.1.RC4 - 21.6 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows version only. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to 2020.1.RC4
KNOWN ISSUES
  • There is a crash issue when modifying primitives under the experimental RTX acceleration with the latest drivers. As workarounds, please stick to older versions as long as RTX is supported. Besides, A fix for it is coming soon.
You can read about new features of OctaneRender™ 2020.1 RC4 here:
viewtopic.php?f=33&t=74515
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.6 (2.82a)
Octane Server - Enterprise Edition - 21.6
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 21.6 (2.82a) Linux
Octane Server - Enterprise Edition - 21.6 Linux
OSX
DOWNLOAD
Blender Octane Edition - 21.6 (2.82a) OSX
Octane Server - Enterprise Edition - 21.6 OSX
