Max 2014
Octane 2020.1 RC2 10.06
2x 2080ti for rendering
1 x 1060 for windows
No idea what's going on here...
Tried to access pin via an invalid ID P_REFLECTION (145)
Tried to access null node pin
Tried to access pin via an invalid ID P_KERNEL (89)
Can't connect node 'Path tracing kernel' (NT_KERN_PATHTRACING, 00000001FCF0FAB0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Tried to access pin via an invalid ID P_RENDER_PASSES (158)
Tried to access pin via an invalid ID P_RENDER_PASS_INFO_MAX_SAMPLES (161)
can't read int/enum from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Can't write int to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Tried to access pin via an invalid ID P_INFOCHANNEL_SAMPLING_MODE (329)
Tried to access pin via an invalid ID P_Z_DEPTH_MAX (257)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Tried to access pin via an invalid ID P_RENDER_PASSES_RAW (277)
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Tried to access pin via an invalid ID P_OPACITY (125)
Tried to access pin via an invalid ID P_RENDER_PASS_CRYPTOMATTE_COUNT (456)
Tried to access pin via an invalid ID P_RENDER_PASS_CRYPTOMATTE_SEED_FACTOR (472)
Tried to access pin via an invalid ID P_RENDER_LAYER (147)
Tried to access pin via an invalid ID P_ENABLED (42)
Tried to access pin via an invalid ID P_LAYER_ID (92)
Tried to access pin via an invalid ID P_INVERT (83)
Tried to access pin via an invalid ID P_MODE (324)
Tried to access pin via an invalid ID P_FILM_SETTINGS (311)
Tried to access pin via an invalid ID P_IMAGER (78)
Tried to access pin via an invalid ID P_GAMMA (57)
Tried to access pin via an invalid ID P_EXPOSURE (45)
Tried to access pin via an invalid ID P_HIGHLIGHT_COMPRESSION (73)
Tried to access pin via an invalid ID P_RESPONSE (199)
Tried to access pin via an invalid ID P_NEUTRAL_RESPONSE (271)
Tried to access pin via an invalid ID P_VIGNETTING (252)
Tried to access pin via an invalid ID P_SATURATION (208)
Tried to access pin via an invalid ID P_HOTPIXEL_REMOVAL (74)
Tried to access pin via an invalid ID P_PREMULTIPLIED_ALPHA (139)
Tried to access pin via an invalid ID P_DITHERING (38)
Can't write bool to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Tried to access pin via an invalid ID P_MIN_DISPLAY_SAMPLES (112)
Tried to access pin via an invalid ID P_SATURATE_TO_WHITE (207)
Tried to access pin via an invalid ID P_WHITE_BALANCE (255)
can't read float_3 from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Can't write float_3 to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Tried to access pin via an invalid ID P_MAX_TONEMAP_INTERVAL (268)
Tried to access pin via an invalid ID P_DISABLE_PARTIAL_ALPHA (310)
Tried to access pin via an invalid ID P_LUT (369)
Tried to access pin via an invalid ID P_ORDER (370)
Tried to access pin via an invalid ID P_DENOISER (389)
Tried to access pin via an invalid ID P_DENOISE_VOLUME (444)
Tried to access pin via an invalid ID P_DENOISE_ONCE (388)
Tried to access pin via an invalid ID P_MIN_DENOISER_SAMPLES (392)
Tried to access pin via an invalid ID P_MAX_DENOISER_INTERVAL (391)
Tried to access pin via an invalid ID P_DENOISER_ORIGINAL_BLEND (390)
Tried to access pin via an invalid ID P_FILM_UPSAMPLING_MODE (488)
Tried to access pin via an invalid ID P_UPSAMPLING_ENABLED (499)
Tried to access pin via an invalid ID P_UPSAMPLING_ON_COMPLETION (498)
Tried to access pin via an invalid ID P_MIN_UPSAMPLING_SAMPLES (497)
Tried to access pin via an invalid ID P_MAX_UPSAMPLING_INTERVAL (494)
Tried to access pin via an invalid ID P_POST_PROCESSING (136)
Tried to access pin via an invalid ID P_ON_OFF (124)
Tried to access pin via an invalid ID P_CUTOFF (486)
Tried to access pin via an invalid ID P_BLOOM_POWER (14)
Tried to access pin via an invalid ID P_GLARE_POWER (64)
Tried to access pin via an invalid ID P_GLARE_RAY_AMOUNT (65)
Tried to access pin via an invalid ID P_GLARE_ANGLE (62)
Tried to access pin via an invalid ID P_GLARE_BLUR (63)
Tried to access pin via an invalid ID P_SPECTRAL_INTENSITY (219)
Tried to access pin via an invalid ID P_SPECTRAL_SHIFT (220)
Tried to access pin via an invalid ID P_CAMERA (19)
Tried to access pin via an invalid ID P_RESOLUTION (198)
Can't read int32_2 from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Can't write int32_2 to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFCA3E1EE0)
Renders freeze, long evaluation, instant crashes.
C. RAM Capacity (i.e. 6 GB)
