Octane Render for Cinema 4D S22
blastframe
Hello!
When we can expect Octane for Cinema 4D S22?
Thank you!
Next build
blastframe
aoktar wrote:Next build
Excellent! That's fast. Thank you, Ahmet! :D
SSmolak
Can we have points cloud instance visibility in Octane Scatter too ? ;)
pinarer
So when it will be ready? till then which version we can use for the S22?
you need to install v2020.1-RC4, it is the only version compatible with S22 at the moment:
viewtopic.php?f=85&t=74531
Please, download and install based on your license type and operating system.
You need to remove from the c4doctane folder, all the unnecessary c4doctane-RXX.cdl64/xdlib files not related with R21/S22 specific versions, and leave only one c4doctane-R21.xdlib file in Program files/Maxon/C4D S22/plugins/c4doctane directory.
It will work also with S22.
V2020 will be officially published very soon, so it will be also available from the personal Downloads section.
ciao Beppe
parsanice
Hey,
QQ: Is the older V4 Octane going to receive the S22 compatibility update as well or not?
MB: Gigabyte Designare-EX X99
GPU: 2x Asus Strix 1070 OC
RAM: Corsair Vengence LPX 32 Gb
CPU: Core i7 - 5820k
PSU: EVGA Supernova 1000w
1x SSD & 2 HDDs
chris6885
Hi, I'm also using v4.05 and just updated to S22. Is there going to be v4 support or has the day finally come now for 2020? :-D
3D Generalist & Motion Graphics Designer
AMD Ryzen 7 1800x 8x 3.6GHz | 2x 11GB EVGA GeForce GTX 1080 Ti FTW3 | 32GB DDR4 3200 RAM
chris6885
No comment on that topic i guess
DinoMuhic
I wouldnt count on this.
S22 needs newer Nvidia drivers on which Octane v4 does not run good at all. They would need to update v4 to Optix7 (v4 uses optix6) and I don't think they will do that anymore.
