Vertex Map Crash
Martange
I have a vertex map in C4D that drives the mix between two textures... Fairly standard. But everytime I open a node editor with a vertex map as the amount of a "mix material" it crashes C4D.
I can erase my vertex map node beforehand (without opening the node editor), replace it afterwards and begin to work with it again without any problem. Then, if I quit and reload the project, same crash happens as before when opening the node editor.
Attached is the bug report zip folder.
C4D R21
Octane 4.05
Dual 2080 Ti
Windows 10
_BugReport.zip
(87.51 KiB) Downloaded 140 times
Depaman
Collapse the preview box on Vertex Map
