MAC: Renderslave in virtual Machine with GPU pass-through
namshubffm
Good Morning Octanians,
i am wondering, if anybody here has experience in using a virtual machine with GPU pass-through as a render slave on a Mac.
As NVIDIA and Apple probably never return to a state of peace and with the ongoing lack of drivers for Mojave or Catalina, i am looking for alternative ways to add an RTX card to my setup - without having the requirement to keep my Windows Systems running. Maybe AMD cards will be a proper option when Big Navi comes around, but for now the NVIDIA options are simply more attractive to me.
My primary system is a Macbook Pro 16" - i9 2,3gz - Radeon Pro 5500M.
With Octane X and Metal support around the corner, which would solve at least any view port issues on the main system, i am considering an additional 2080 in an external enclosure and using direct pass-through to a Windows Virtual Machine, in vmware fusion, to use it as directly-connected slave. (note: vmware fusion has AFAIK no official egpu support, however i saw some workarounds to make it accept removable devices as GPU - so at this point this setup idea is a wild guess to me)
I am aware that using a Intel NUC or any other micro build and just using it as normal slave, will be less problematic and probably having better performance.
Any thoughts? I tried the search function but i am either blind or this topic was indeed never discussed
Kind regards
nams
the easiest way is to install Win 10 via Bootcamp, then you can use an eGPU box with Nvidia inside, without custom scripts, and totally plug and play.
I don’t think that virtual machines can work with CUDA :roll:
I have done this to be able to work with my MacPro, while waiting for OctaneX.
Btw, OctaneX beta testing is just started:
viewtopic.php?f=7&t=74511
ciao Beppe
