OctaneRender™ for Blender 2020.1.RC3 - 21.5 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux, and Mac OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Updated to 2020.1.RC3
  • Removed lock step length pin in medium nodes. This has been replaced by a select box that enables using volume step length for volume shadow step length
  • Added Octane Resource Cache System("Render Properties - Octane Server - Octane Resource Cache")
  • Basically, Octane will cache the images and meshes to accelerate the interactive rendering initialization
  • Supported Object Data Node("Shader Node Editor - Input - Octane Object Node")
  • Allow using the object transform as an Octane Transform input
FIXES SINCE LAST RELEASE
  • Fixed front projection issue under Blender Camera Mode
  • Fixed light flash issue
  • Fixed render passes issue in final renders when the preview pass is different than Combined
  • Fixed Particle Show Emitter toggle issue
  • Fixed slow IPR issue when both keep environment and alpha channel ticked
  • Fixed Octane viewport crash
KNOWN ISSUES
  • There is a crash issue when modifying primitives under the experimental RTX acceleration with the latest drivers. As workarounds, please stick to older versions as long as RTX is supported. Besides, A fix for it is coming soon.
You can read about new features of OctaneRender™ 2020.1 RC3 here:
viewtopic.php?f=33&t=74419
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.5 (2.82a)
Octane Server - Enterprise Edition - 21.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 21.5 (2.82a) Linux
Octane Server - Enterprise Edition - 21.5 Linux
OSX
DOWNLOAD
Blender Octane Edition - 21.5 (2.82a) OSX
Octane Server - Enterprise Edition - 21.5 OSX
linograndiotoy
My advice is to keep RTX off for this release, waiting for an upcoming fix.
