Baking Metallic Map
3dreamstudios
Looking for a way to bake out my textures for use in Unity. I don't see a metallic option under the baking camera. I can get the following....
Diffuse
AO
Roughness
But no Specular or Metallic, that I can see. Hopefully, I'm missing something. Can someone fill me in?
juanjgon
Baking specular lighting makes no sense, it depends on the camera position, so it must be computed by the engine (Unity) from the material specular parameters or from a specular texture map.
3dreamstudios
juanjgon wrote:Baking specular lighting makes no sense, it depends on the camera position, so it must be computed by the engine (Unity) from the material specular parameters or from a specular texture map.
Maybe I didn't ask it correctly.. Every PBR texture you'll find out there that has any metallic or specular surface will have a corresponding AMOUNT map. Black to white showing the different amount of specular or metallic.
When you use an atlas map in a game engine you try and combine as many materials into one MAP set. That means you will have some materials/surfaces in this map that are specular/metallic and others that may not be....metal on sword and leather on hangle.
Does that make more sense?
juanjgon
Hmm, perhaps the problem is that I'm talking about baking the scene lighting, not building pbr texture maps. I suppose that the Octane baking feature is designed to bake the scene diffuse/GI and AO lighting, not to bake texture sets, but I can be wrong. To be honest, I'm not an expert in lighting or texture baking for game engines.
3dreamstudios
juanjgon wrote:Hmm, perhaps the problem is that I'm talking about baking the scene lighting, not building pbr texture maps. I suppose that the Octane baking feature is designed to bake the scene diffuse/GI and AO lighting, not to bake texture sets, but I can be wrong. To be honest, I'm not an expert in lighting or texture baking for game engines.
Fair enough...nor am I! lol. Just trying to learn how to best take my Octane Assets from LW and get them into Unity for our VR projects. Did not want to have to go into Substance or other packages and re-do every material.... But may have to.
I don't know why the correct layers couldn't be baked out from Octane, it has to know what those are in it's buffers (or whatever) at render time, to render the surface properly.
Is that something you could ask someone at OToy about? I thought I had seen this exact thing in the C4D implementation... But again, I'm not super knowledgable about the workflow.
vitusfilms
Did you figure out how to bake a metallic map?
omardex
hello, One workaround I've been using is to input the map I want to bake into the diffuse/albedo, and use the diffuse material pass to get such map.
I do this for any map that octane doesn't have a pass or info pass.
I export a lot of client work for sketchfab, and unity, PBR maps are required to get as close as possible from the render that octane provides.
what could be ideal is to have in the new AOV inclusion any material channel as export.
the c4d the plugin offer solo material texture preview for texture isolation this could be expanded as a solution too for map export.
I hope this as workaround works for any of you.
Omar Tavera
Awesome Generalist
omardex.artstation.com
Octane render for c4d but moving more toward standalone with one 980ti
pegot
omardex wrote:One workaround I've been using is to input the map I want to bake into the diffuse/albedo, and use the diffuse material pass to get such map.
Can anyone elaborate on this workaround more? I don't understand how ones gets a PBR Metallic map from this technique.
Are there any plans to implement a Metal pass for Octane? I often have to prepare PBR textures of Octane projects for gLTF and going into Substance Painter isn't always an option.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
omardex
There is a better method now, you can flag your materials as a custom AOV create a custom AOV pass and effectively render a mask for your metallic materials
the mask is basically a metallic map, and you can input it as a texture in the metallic channel
make sure that you have your metallic materials as artistic, when you bake your albedo/diffuse this color is used by your metallic materials to define its properties.
Omar Tavera
Awesome Generalist
Return to “Lightwave 3D”
