Animation in orbx for orc
Moderator: BK
bodenarr
is ist possibel to save a animation in orbx for a upload to orc
I want to render an animation made in DAZ3D in the cloud
win 8 64bit / Xeon X3450 / 20GB RAM / quadro 600 / carrara pro8; Blender
http://www.on-sallmann.de / Germany / Rhein-Main
I have not tested this, but with you export the scene via the plugin System tab, the resulting ORBX should be renderable via the cloud. You may need to tweak it first in Octane Standalone to work out which rendertarget to render.
bodenarr
thank you for your answer
I have tried to export out of the plugin
and than import into standalone
bt no animation is saved .. I do not find the switch to enable it...
bodenarr wrote:thank you for your answer
System->Alembic Export will also save an OCS file which you should be able to load into Octane Standalone to render the animation.
Return to “DAZ Studio”
