Extending OctaneLight object with MaxScript (help needed)
cmatias
Hi.
I'd like to extend the OctaneLight to make it an "OctaneLight video projector" (I'll call it OCProjector).
First of all, I'm a real beginner at Maxscript coding... but I am a quick learner ;)
So, here is what I want to achieve:
- Extend the OctaneLight class with a new class called OCProjector
- Add some parameters to this new class like the projector size (WxHxD), so I can draw a box behind the OctaneLight plane.
- Create & Assign a Distribution map (RGB image) to the OctaneLight
- Create & Assign an Octane “Perspective Map” to the Projection slot of the “RGB image” distribution map.
- Create & Assign à “3D transformation” to the “Plane Transformation” of the previous “Perspective map”.
- Add rollout controls to the OCProjector to control Rotation, Scale, and Translation of the previous “3d transform”, directly from the OCProjector rollouts.
I already found the way to achieve some of those functions, by defining a new class object plugin from Maxscript :
plugin Light OCProjector
classID:#(0x47db14ff, 0x4e9b5f91)
category:"Octane"
extends:OctaneLight
replaceUI:false
Then, I can create visual controllers by declaring “parameters” and “rollout” interface:
parameters pblock rollout:params
  projboxwidth type:#float animatable:false ui:projector_Width default:40.0
  projboxheight type:#float animatable:false ui:projector_Height default:20.0
  projboxdepth type:#float animatable:false ui:projector_Depth default:20.0
rollout params "Projector Parameters"
  Spinner projector_Width "Width :" range:[0, 1e9, 40]
  Spinner projector_Height "Height :" range:[0, 1e9, 20]
  Spinner projector_Depth "Depth :" range:[0, 1e9, 20]
To display the projector, I’ve defined a local variable “meshObject” to store the “box” representing the videoprojector, so I can display it within the “on getDisplayMesh do” method using the statement:
  if (meshObj == undefined) do
     meshObj = createInstance box [...]
  meshObj.mesh
As I can see on the Maxscript documentation about Scripted light plugins (https://help.autodesk.com/view/3DSMAX/2 ... 7C0D57_htm)
Current limitations prevent certain plug-ins from being extended, in particular those with custom creation managers. These include target light plug-ins. You can tell if a plug-in is not extendable if your new rollouts do not appear.
In my case, the rollouts appear ! (good news)
By the way, on the same document, there’s a sentence about the Create tool :
“If a create tool is specified, it will override the delegate's create tool.”
Actually, if a set no “Tool Create” delegate’s function, my plugin simply crashes 3ds Max when I try to draw (create) the OCProjector light on the viewports.
I've also being trying to set a "Tool Create" delegate's function with the same crash issue...
So here I am stucked at this “tool create” point.
Does anyone of you have an idea?
Regards.
C MATIAS
HHbomb
do you see the scripted camera plugin ?
Perhaps some undefined locals ?
plugin Camera CamTest_DisplayMesh
classID:#(0x6ca13d13, 0x12afbfd4)
category:"Standard"
extends:FreeCamera
local lastR1, lastR2, meshObj
radius1 type:#float animatable:true ui:r1_amount default:40.0
radius2 type:#float animatable:true ui:r2_amount default:20.0
rollout params "CamTest Parameters"
Spinner r1_amount "Radius 1:" range:[0, 1e9, 40]
Spinner r2_amount "Radius 2:" range:[0, 1e9, 20]
meshObj = createInstance torus radius1:radius1 radius2:radius2 mapCoords:false
lastR1 = radius1; lastR2 = radius2
if radius1 != lastR1 do (meshObj.radius1 = radius1; lastR1 = radius1)
if radius2 != lastR2 do (meshObj.radius2 = radius2; lastR2 = radius2)
meshObj.mesh
)--end on getDisplayMesh
tool create
on mousePoint click do (nodeTM.translation = gridPoint;#stop )
)--end tool
)--end plugin
cmatias
HHbomb wrote:Hi,
My local variables aren't used yet before it crashes...
I'm actually only declaring the rollouts, but it crashes as soon as I click on the viewport to create the light :
category:"Octane"
extends:OctaneLight
replaceUI:false
  local prw, prh, prd, meshObj
Return to “Autodesk 3Ds Max”
