Hello octane users, is it possible to integrate iage textures into octane material as is (not as external link)?
I work at home and at work, and file paths differ sometimes. So, i usually click and reajust path for each texture.
Ideas?
Integrating textures into material
So you should use relative paths, even use "save project with assets" command to collect/transfer your scene. File names will be converted to relative paths
You can also set multiple alternate search paths in C4D Preferences>Files>Paths>File Assets. This way you can have both your home resources path and your work resources path active at the same time. If C4D can't find it on one path, it will check the other.
