Substance Engine crashes Octane
Scourgewolf
Whenever I implement a Substance in my Octane material, the second I send the scene to render in the LiveViewer it crashes trying to create the material for render.
File in question: https://mega.nz/file/at4UBSaL#F8y2GlsyY ... AwIJJLJ6YA
(Note: TGS MeshBoolean needed)
OS: Windows 10 Pro 64-Bit Build 18362
CPU: AMD Ryzen 7 1700X ~3.4GHZ
GPU: NVIDIA GeForce GTX 1070
Driver: Game Ready Driver 445.75
RAM: 32 GB
Version: Cinema 4D R21.207
Found this in the bug report:
Critical_Log
		[21:55:51] CRITICAL: Method net.maxon.node.interface.nodeslib.724ec285c557822bf8b9d7fab088470b not implemented by NodesLibImpl (requested by file:///C:/Program Files/Maxon Cinema 4D R21/plugins/Redshift/redshift4c4d.xdl64). [object_impl.cpp(2669)] [objectbase1.hxx(427)]
		[21:55:51] CRITICAL: net.maxon.nodes.framework : Error while initializing the method table of interface net.maxon.node.interface.nodesystem. [object_impl.cpp(2528)] [objectbase1.hxx(427)]
		[21:57:33] CRITICAL: Stop [int_customgui_description.cpp(5526)]
_BugReport.txt
File in question
(615.74 KiB) Downloaded 164 times
Plugin version?
Scourgewolf
aoktar wrote:Plugin version?
2019.1.5-R2
2019.1.5-R2
2019.1.5 will not get updates. Please try with latest 2020.1 build
Scourgewolf
aoktar wrote:
2019.1.5-R2
Still crashes.
What do I need to avoid this? Also convert booleans to meshes to avoid the requirement for an extra plugin.
nejck
aoktar wrote:What do I need to avoid this? Also convert booleans to meshes to avoid the requirement for an extra plugin.
Aoktar, that just means you don't have that specific Substance file which contains the Substance asset (textures and material settings and all that). :) If you want to replace it with another Substance then you can get access to the free ones on Substance Source (https://source.substance3d.com/).
Scourgewolf
No need. Booleans baked and Substances attached here: https://mega.nz/file/305jVZZT#BgUn8KNQv ... -Qb8luCeh4
Ok thanks! I can reproduce the problem.
Problem is that "C4D shader resolution" for shader to texture which is very big somehow. Seems like a parameter issue on settings. Disable previews and set "C4D shader resolution" again in this material as a work-around. I'll try to find the reason.
Well!
There's two standard material with substance shaders. These materials is giving wrong resolution values(big numbers) for shader to texture feature. And it's crashing. Remove these materials and it will work fine. I'm adding some controls to avoid this issue.
