Doesn't launch on OSX
skyrick
I tried to launch the demo on my mac pro 4,1 before bought this renderer.
First : Are there 64 bits version ??
Second : The 32 Bits version doesn't launch on my system :(
I've a Quadro 4000 Mac version
Idea ?
I've already downloaded the CUDA 3.2 devversion
Regards,
Sky'
abstrax
skyrick wrote:Hi,
Idea ?
Regards,
Sky'
The 32bit version should run on your system. If not it's a different problem - probably a driver problem. If you are using Mac OS 10.6, please update to the latest version (10.6.8 as far as I know) and then install CUDA toolkit 4.0 (get it from here: http://developer.nvidia.com/cuda-toolkit-40#MacOS) and then the CUDA driver 4.0.19 (get it from here: http://www.nvidia.com/object/mac-driver-archive.html). After that, reboot and try again.
Marcus
skyrick
Thanks ! It's work fine !
you should change your tutorial page, the CUDA stuff version is wrong.
So, again 2 questions :
1/ Where is the samples with the mac version ?
2/ When I buy the full version, a 64 bits mac version exist or only this 32 bits version ?
Regards,
Sky'
abstrax
skyrick wrote:Thanks ! It's work fine !
Regards,
Sky'
Hi Sky,
we will fix the downloads and tutorial pages. For Macs we only supply a 32bit version. We plan to switch to 64bit, but haven't found time to do it, yet. Unfortunately I don't under stand the first question.
Marcus
skyrick
So, I'm waiting for the 64 bits version to buy your product.
For the first question, I found the samples files on the download page at the right size.
Regards,
Sky'
