Light Bounce intersection
Sub forum for help and tutorials.
snooz
I'm sure this problem have been already posted, but i don't find the good keyword...
My problem is about to plane interesected (cf img)
You can see an highlight over the intersection of my wall and floor. How can i fix that ?
Thx
Valentin
what's rayepsilon value? And dimension of objects?
snooz
Ray epsilon by default : 0.0001
and my scene is 1:1 scale (3 meters height)
I tried to change my ray epsilon but same shit
frankmci
It's hard to tell if you're really a getting light leak as it appears, or if it's just a quirk of your geometry shape and lighting setup. If your scene is what I am imagining, that might actually be correct. It looks like a simple scene; can you upload it, or a stripped down version with just the visible geometry and lights in your example?
nejck
Could it be a phong shading issue perhaps? Try messing with that a bit :)
you can use the Info Channel Kernel to check the geometry, try with Geometry, Smooth, and Shading Normal passes.
ciao Beppe
snooz
Hi !
there is my scene :
https://drive.google.com/open?id=1p6iuB ... TPT2IkcDPh
I removed my shader
snooz wrote:Hi !
there is my scene :
I removed my shader
frankmci
snooz wrote:Hi !
there is my scene :
I removed my shader
Try zipping your scene and the using the "Upload Attachment" button on the bottom of window, then "Choose File", then "Add the File".
snooz
thx ;)
scene_arche_test.zip
(47.67 KiB) Downloaded 238 times
Return to “Help / Tutorials”
