Simple square OSL shader help !
Sub forum for help and tutorials.
pxlntwrk
Hello I would like to draw a simple square with the language osl.
I found this piece of code (source: http://www.fundza.com/rfm/osl/repeats/index.html)
// Returns a value in the range 0 to 1.
// 0 indicates the x,y point is outside the square, and
// 1 indicates the x,y point is fully within the squere.
float pntInSquare(float x,
                  float y,
                  float x_center,
                  float y_center,
                  float x_width,
                  float y_width,
                  float blur)
float minx = x_center - x_width/2;
float maxx = x_center + x_width/2;
float miny = y_center - y_width/2;
float maxy = y_center + y_width/2;
return smoothstep(minx, minx + blur, x) * (1 - smoothstep(maxx, maxx + blur, x)) *
       smoothstep(miny, miny + blur, y) * (1 - smoothstep(maxy, maxy + blur, y));
shader
square(float   s_center = 0.5,
       float   t_center = 0.5,
       float   s_width = 0.4,
       float   t_width = 0.4,
       float   blur = 0.01,
       color   bakcolor = 1,
       color   patcolor = 0,
       float   s = 0 [[int lockgeom = 0]],
       float   t = 0 [[int lockgeom = 0]],
    output color resultRGB = 0)
float blend = pntInSquare(s, t, s_center, t_center, s_width, t_width, blur);
resultRGB = mix(bakcolor, patcolor, blend);
but I can't get it to work with Octane.
Could someone guide me on what needs to change for Octane to make it work.
Many thanks in advance
pxlntwrk.net
You wish math help not octane. Take a look to presets. For example grid1.osl, you can obtain a square with that.
pxlntwrk
aoktar wrote:You wish math help not octane. .
yes i agree with that!
aoktar wrote:Take a look to presets. For example grid1.osl.
yes , you are right again,
my problem with grid1.osl is that once configured, when i change projection for perspective for example, the square becomes a grid again,
so how to restrict repetition?
pxlntwrk.net
This script may be hard to manage, I can give very simple one if your need is just to draw a simple grid.
pxlntwrk
aoktar wrote:This script may be hard to manage, I can give very simple one if your need is just to draw a simple grid.
If you have time, that would be really nice!
just one square :D
thanks
pxlntwrk.net
Return to “Help / Tutorials”
