Can't get ORBX Proxies to work
pegot
I load an ORBX Proxy but can not get it to work either in 2020.1 RC2 or 2019.15. Is their some other steps I need to take that is different from earlier versions? All I used to do was load the ORBX into the tab in Octane Properties. That still works for me in 2019.1.4 / 18.6 (for Blender 2.79a). I can not get it to work in any of the Belnder 2.8 releases.
Is this feature supposed to be working?
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
pegot
Can any dev respond to this, or do I need to submit a help ticket?
Thanks.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
J.C
pegot wrote:Can any dev respond to this, or do I need to submit a help ticket?
Thanks.
Can you share the ORBX file that is not working? I've tested mine and it is working fine with latest release.
System – Windows 11
pegot
See attached zip.
Only the version from 2019.1.4-18.6 for Blender 2.79b works on my system. The newer ones for Blender 2.8 don’t. They just render my Proxy box as is. I even tried changing all the Mesh types to no avail. I’m thinking it has to be something strange with my system.
The ORBX was created with Octane Stand Alone 2019.5. I included the OCS for that as well - just a very simple test scene.
Thanks for checking on your end!
OctaneBlender-ProxyTest.zip
(271.19 KiB) Downloaded 261 times
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
grimm
You are using a Geometric primitive, but I'm not sure that the Blender plugin supports those yet?
J.C
It's not working on my side too. I think it's because of the geometry primitive. Scenes with regular meshes should work. In C4d plugin this works so I guess Blender plugin has something missing in that matter.
System – Windows 11
pegot
I will try with other no primitive geometry. But it works fine in the older Blender 2.79a under 2019.1.4 / 18.6.
I think I will also post this in the bugs section now - thanks for testing.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
pegot
I can confirm it works as long as non-primitives are used in the ORBX export. This limitation currently doesn't exist in the pre Blender 2.8 builds so I hope it can be fixed soon. I have a lot of more complex scenes that hare made up of lots of primitives.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
pegot
Upon further investigation I have found the following:
Proxy feature in latest Octane Blender builds for Blender 2.8 will fail if a PLACEMENT node is used. This of course prevents us from exporting as a proxy any transforms or animations done in Stand Alone. It also limits the complexity of the scenes that can be exported - pretty much limiting it to single objects
Neither of these limitations ever existed in Octane Blender for Blender 2.79.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
We'll fix this in the next builds.
Return to “Blender”
