Had repeated crashes on an animation - bug report attached.
Have optimised the scene, then had a render failure check log - also attached
Spent over an hour trying to sort so any help here appreciated, thanks and sorry if it's a howler
Having a an issue, could be simple...
- Burgess AK
- Attachments
- Octane log .txt
- (36.83 KiB) Downloaded 202 times
- _BugReport (2020_03_11 05_42_49 UTC).txt
- (531.34 KiB) Downloaded 138 times
C4D R20
1 x GEFORCE RTX 4090, 64 GB RAM
If you believe in telekinesis, raise my hand
Version numbers/Driver?
1-Have you checked VRAM usage?
2-Using OOC?
3-Did you deleted materials for testing?
2-Using OOC?
- Burgess AK
Hi Aoktar,
sorry this took me a couple of days to sort, lots of trial and error.
I checked all of things you mentioned, thank you.
The issue, through stripping the scene right back and testing individual elements, was actually down to an object that I had used a c4d 'poly reduction' on - it left me with a bunch of tri's which was what was causing an issue with octane. I remeshed this object with a volume builder/mesher and the problem was solved. So, not an Octane issue.
Thank you for your assistance, I have replied to says thanks and just in case anyone else has a similar issue.
Thanks again
Thanks again
C4D R20
