How to enable 2xRTX 2080?
Stelios20
Hello,
I just bought a new pc with 2xRTX 2080 super, with a connection between them (like SLI, I do not know much). When I am rendering octane uses only 1 of them.
How can I enable both? I use octane plug in for blender.
Thank you guys!
Stelios
acoval
Hi , I had the same question today.
You just enable any extra GPUs in the Device Preferences, under Octane Server.
Stelios20
They seem to be active but only one works for rendering.
Stelios
J.C
If you are using Free Tier version you will be limited to one GPU available for rendering
System – Windows 11
Stelios20
Hey,
It is a studio license. I updated the drivers to 442.59 but still not working.
Is octane compatible with nvlink?
Stelios
J.C
Stelios20 wrote:Hey,
Stelios
RTX is available since Octane 2020.x version.
Octane is compatible with nvlink since version 2020 as far as I remember.
System – Windows 11
J.C
It looks like both are available for rendering. Check your GPUs using GPU-Z or in task manager when checking GPU performance switch to Cuda.
System – Windows 11
Stelios20
They are working! GPU-Z shows them working properly!
Could you inform me about the LiveDB and how it works? I cannot find it at the Editor Type options as it used to be in the past!
Thanks for your help!
J.C
Stelios20 wrote:They are working! GPU-Z shows them working properly!
Go to in Blender's main menu click Window > Octane DB
Select a material and right click import.
System – Windows 11
Return to “Blender”
