Render queue not switching with network rendering on?
LFedit
Anyone else have this problem? We have it now on 2 computers, so its not a single computer issue. But when we render stills with the render queue and network rendering enabled, it gets hung up at the end of the render... it must be something with saving or something? But then to get it to switch, I have to turn off network rendering, then turn it back on right away. Then it will switch to the next render in the queue. We are trying to find a solution to queueing up renders over night... the render server works great for animations.... 0 crashes and distributes the renders perfectly. But still can't figure out this render queue to work for still stills consistently. Sucks queueing up 10 renders that should take 20 minutes a piece and come in and it says 15 hours, never switches.
What happen if you firstly connect the Slaves in Live View, before starting rendering?
ciao Beppe
LFedit
I usually use the live viewer to render, but I want to use the denoiser with render region. Is this possible with the live viewer? Seems render region just goes on forever so denoiser never kicks in. Would like to keep it so it is using denoiser at the end because I am working on some very heavy CAD scenes.
But to answer your question. Same thing. It just doesn't switch, until I turn off network rendering, then let them disconnect (2 seconds) then turn network renering back on. Then it will save and move onto the next render. But the point of the queue is to not babysit it....
I can't be the only one experiencing this right?
Which version are you using exactly?
There are two types of Render region icons from some time, the red classic render Region, and the green Film region, trt with this one.
About the slaves with Batch Rendering, do you have more than one Master in the same LAN?
Please, open a couple of scenes, then go to c4doctane Settings/Others tab, and, at the bottom of the panel, enable all the Log option checkboxes:
Then, load the scenes in Render Queue for few frames, and share the c4doctanelog.txt file that you find in c4doctane directory, or in the path specified in Settings/Others panel, at the end of the rendering session, thanks.
ciao Beppe
