VDB exported from Bifrost problem.
C. RAM Capacity (i.e. 6 GB)
Hi I am trying to render a smoke simulation from bifrost so I exported a vdb from it, It was an example from bifrost browser, but maya 2018 crashes everytime I am trying to render or import the vdb sequence as orbx proxy, this do not happend with a vdb exported from fumefx only from bifrost, octane renders vdb volumes from fumefx, do you know how can I render a vbd sequence from bifrost?, or let me guess vdbs from bifrost are not supported?, thanks.
I'm going to move this topic to bug-reports section.
Because if this crashes - this most likely is a bug. Just so far I'm not sure if this is a plugin bug or the Octane engine itself crashes from this input...
I need an ORBX file that crashes on you.
Hi Jim, the vdbs I am trying to render are exported from the samples that come with maya 2018 in the bifrost browser, I tried the smoke ones, I just changed the "file_cache" node to vdb in the Bifrost Graph Editor of the example, either option in the node Traits 2_4 or 5 make maya crash anytime I try to render the vdb sequence with octane.
My graphics cards are 3 x 980ti and 1 titan black 6gb.
Maya 2018 sp6.
Nvidia Drivers 430.86
OctaneRender for Maya 4.05-13.48 [STABLE]
Windows 10 pro 64bits
Maya 2018 sp6.
Would be useful if you give me this VDB file that crashes on you.
If I understood correctly, you just create the ORBX proxy node, and then create the Octane volume node inside the proxy's node-editor window using this VDB file, and Maya immediately crashes?
This is a vdb frame I exported from the bifrost smoke examples, If I try to import it in a orbx proxy node maya crashes, if I try to render it once imported from the traditional import menu from maya, maya crashes too.
- Attachments
- file_cache.0001.zip
- (3.18 MiB) Downloaded 359 times
