visbility toggle crashes server
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
protovu
With Render Preview active, I am having consistent Server crashes when toggling : Show in Viewports and Show in Renders
Blender Octane 2.81.1 -
Octane v.20.7
win10 64
amd3950
64 ram
2x rtx 2080 super
latest nvidia driver 442.19
linograndiotoy
protovu wrote:With Render Preview active, I am having consistent Server crashes when toggling : Show in Viewports and Show in Renders
Octane v.20.7
win10 64
amd3950
64 ram
2x rtx 2080 super
Does it always happen, in any scene? And does it happen with RTX on or off? Or in both cases?
protovu
Hi Lino,
It is not consistent, but it seems that the simpler the scene, the less likely. The Scene I am on now is not that bad, actually, about 34 mb.
At one point, I suspected that perhaps it was happening because I was interrupting the denoiser as I toggled items on and off. Not the case.
Then, I thought that maybe Collections were more likely to cause the crash than objects, but just tested and an object toggle crashed it. Not the case.
Thought maybe, more complicated meshes? Not the case. Just now crashed when toggling a plane. Once restarting the Server, the plane then behaves.
Generally, it is behaving better, now. It is almost as if it is doing machine learning.
I have not tried RTX. I would like to but cannot see where to enable it. Is it available for me with 2.81.1?
Rick
DrawFun
Thanks, protovu and Lino! It will be fixed in the coming version!
DrawFun
linograndiotoy
protovu wrote:Hi Lino,
Rick
RTX is available in any 2020 integration. You can enable it from the Device Manager.
If it happens with RTX off, there's no need to test it with RTX on by the way.
Return to “Bug Reports”
