OctaneRender™ for Blender 2020.1.XB3 - 21.3 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Updated to 2020.1.XB3
    • Updated Dirt Texture according to SA
    • Added "Dirt Visibility"
  • Supported Octane Output ("Property - Output - Octane Output") as it is in SA
    • Supported to customize "Octane Export Mode", "Export File Format", and "EXR Compression Type" as SA
    • The export results are put under the "Output Path"
  • Supported Mesh Type Optimization("Property - Object Property - Octane - Mesh Type") for final animation render
    • Avoid duplicate transform updates for objects that are not Movable
    • Avoid duplicate mesh data updates for objects that are not Reshapable
  • Added a new experimental "Auto" mesh type to detect and apply the optimization automatically
    • e.g. it can detect and apply "Reshapable" rules for the objects that are used as smokes
    • It's an experimental feature to help users get rid of the manual mesh type assignment. Please let us know if there are any cases that are not covered and handled incorrectly. We will keep on its improvements.
  • Optimized mesh updates in viewport preview
  • Removed redundant uploads for meshes(except meshes that are reshapable, modified, or in edit mode)
  • Supported Global mesh type
  • Supported object layer settings for Orbx proxy
FIXES SINCE LAST RELEASE
  • Fixed some issues in Orbx Proxy
  • Fixed the volume render issue
You can read about new features of OctaneRender™ 2020.1.XB3 here:
viewtopic.php?f=33&t=73728
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.3 (2.81)
Octane Server - Enterprise Edition - 21.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 21.3 (2.81) Linux
Octane Server - Enterprise Edition - 21.3 Linux
OSX
DOWNLOAD
Blender Octane Edition - 21.3 (2.81) OSX
Octane Server - Enterprise Edition - 21.3 OSX
